Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Peggy M, Hotrod Lincoln, Otto Skorzeny), 193 guests, and 5 robots.
Topics128,284
Posts1,058,531
Members48,490
Ok; how do you guys/gals make those Offy valve covers stop leaking oil on the 235? What's your secret to a dry engine?
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
Hello Jerry -
I used General Motors gasket sealer (bought it at a Chevy house) and sealed the gasket to the head. I put the valve cover on the gasket with NO gasket sealer (so I could remove it to adjust valves). I had to drive the truck several times and each time, after the engine heated up. I turn the nuts on the cover to pull it down tighter and tighter. Finally, after about five-seven times, it quit leaking. By tightening the cover, I eventually made a deep enough groove in the cover to cause it to seal!
I know it's not very scientific, but it worked for me. Try it! grin
Joe
. . . . I made a deep enough groove in the GASKET to cause it to seal . . .
Napa (Victor) makes a thick (1/4") 216 gasket that works great! I use Avaition Permatex liquid to glue it down. No leaks for 55K miles!
47 Fleetmaster, Hotrod 6, 5 Speed
50 Sedan Delivery, 327, 5 Speed
Jerry You might need to check to see if the bottom edge is flat. Put it on a flat surface and go around it with a piece of paper or feeler gage to see if there any gaps between the bottom edge and the flat surface. I have a Waynes valve cover on mine and had to take to a machine shop to have them sand it flat along the bottom edge. It cost about 10 bucks, but it works great now.
Good luck
George
wink
Good point George!
One problem with cast covers is they can be too long, and the gasket too short. If that's the case, get two of the thick gaskets, Felpro makes them. Overlay them and cut each side with a razor blade. Best sealant I've found is 3M Weatherstrip Adhesive, just follow the instructions.
Fred
52 3600
69 C-10
our trucks aren't suspose to leak grin
Redryder pix
My Hotrod
