3 members (dunfire, Napco Man, TUTS 59), 61 guests, and 2 robots.
Topics128,035
Posts1,055,564
#459388 10/08/2008 12:41 AM
I have a 49 Chevy one ton that has a 5 lug rear end bolt pattern. Is this common for this year? All that I have found in the search section does not include a 5 lug pattern. Does anyone have a measurement guide to this pattern? I will need to upgrade the rims and tires as they still have the split rims. All help would be appreciated.
I can only think of one of 2 possibilties that it would have a 5 lug rear, 1-someone has swapped out the rearend, possibly for a Dodge or IH, or 2-It's not a 1 ton, but perhaps a 1 1/2 ton. Are the fronts 5 or 8 lug?
Bill Burmeister
Thanks for the response. I checked the front and they are 8 lugs. Now the truck was originally a fire truck. Did they put a heavier rear end in those trucks?
Not from the factory. It might have been done later in it's life to increase load capacity.
Bill Burmeister
Count the bolts on the pumpkin.
~Jim
There are 10 bolts on the pumpkin
Could be a GM 10 bolt. Look for any identifying marks on it.
~Jim
measure across the studs at the widest point looking at the studs as if they were a star, out of the 5 studs 2 will be wider, if they are 4.5" center to center its a GM rearend
Tim
1952 Chevy Shortbed
Photos in Photobucket
