7 members (Forty9, fonz8261, jkreiner, treegrower, Bill Hanlon, Wally / Montana, TexasJim50),
51
0
Mod | | | Forums66 Topics128,074 Posts1,055,914 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45943 06/06/2005 10:34 PM | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | My son and I are starting our 57 panel Project. We bought a 77 K5 Blazer for the frame and drive line. (Yeah its a 350... and I know you don't all approve) I don't have a problem lengthening the wheel base 7-1/2" but the front tread width is about 6" wider on the K5. (The rear should be fine.)
I noticed that the rims on the K5 are very deep... (I don't know how to explain it) the mounting surface is such that the tires are off center to the outside.
Are there any stock rims readily available to change the offset and narrow the tread width?
Also, will it look strange with different rims on the front than the rear?
I tried posting this in the general truck forum but haven't gotten any replies... I really need help figuring this out. | | |
#45944 06/09/2005 3:47 AM | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | Inky, I can't contribute to this from a technical standpoint, as we've never tried such a swap.
But since nobody else has responded either, I CAN make a social contribution - don't worry about what anybody else thinks of your project. The purists will frown on the 350, the rodders would have done something differently, and the jerk next to you in his chopped street machine at the gas station is going to look down his nose anyway.
Have fun with your project and be proud of it! I have an old '76 K5 with a new 350 that needs a new job, so I'll be keeping an eye on your progress for ideas! - K | | |
#45945 06/09/2005 3:52 PM | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Kimberly,
Thanks for the encouragement. I'm sure I can make it work... Like my tag line says... I was just hoping a fellow bolter could give me the "easy" answer. | | |
#45946 06/10/2005 3:24 PM | | Anonymous Unregistered | | Anonymous Unregistered | You can get wheels with different backset, but if you have disc brakes up front, be careful that your wheels will clear the calipers. | | |
#45947 06/11/2005 3:18 AM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | 73 and up stock 4x4 wheels are off set a little more than the older wheels to clear the disk brake calipers.they accomplished this by making the center of the wheel (where the lug nuts are ) slightly deeper. | | |
