4 members (Steelonsteel, texas46, Ponchogl, Bill Hanlon), 65 guests, and 1 robot.
Topics128,022
Posts1,055,382
Members48,422
#459152 10/07/2008 5:03 AM
I need to verify the model number of my carb to order a rebuild kit. Where do I find the necessary numbers? Are there numbers on the carb? Slim.
1957 3805 Panel
It's not how you fall down, but how you get back up.
1 Offline
what kind of truck? 235 motor or? if its a one barrel rochester "B" the napa # for the kit is:2-5158 under $15 bucks.
Well slim if it is a orginal carb. from GM it had a tag on one of the top carb. screws. What brand is the carb Rodchester,Carter etc. You will have numbers on the carb that look like this
Foot Note Idle speed for the M/T trans.450 to 500 RPM AT Trans 425 to 500 RPM
#7024000,001
7023004.005
702000,003,005,106,107
7013000,003,005,955,956
70119000
7011102,70212127,129,502
7009656,657,784,
7011656,657
This carb was used on 1957 to 1967 engines 230,235,250 cu. engines
Soarce Rochester Carburetors
1 Barrel-- Models B,BC,BV
Hope this helps some.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
Don G. #459336 10/07/2008 11:13 PM
Riding in the Passing Lane
If it's got the original Roch. carb it's like Don says. There was a tag under one of the top cover screws but most of the time they are gone by now. You can get a kit by aplication because one number covers a wide range. If it has a carter the number is stamped in the fuel bowl or throttle body.
1972 Chevy c10 Cheyenne Super
