4 members (baldeagle, Jon G, Oswald, 1 invisible), 57 guests, and 3 robots.
Topics128,015
Posts1,055,334
Members48,419
#458473 10/04/2008 5:55 PM
I have not been able to locate in any of the online manuals the location of the body mounts or pictures of the actual mounts. I was wondering if someone knows where that information would be.
Thank you
Jackyl #458495 10/04/2008 8:03 PM
Jackyl,
Have you removed the existing mounts or are they missing. They actually come with shims for final body alignment so if they are still there diagram the remnants. My rear shackle mounts had one shim on the frame (PS) and one on the cab (DS) the front mounts and the radiator also call for shims as required during assembly.
You can see the shims in this photo:
http://community.webshots.com/photo/2275285170102454676BEQvTZ
Brad Allen #461074 10/13/2008 3:34 PM
No still have them, but moving the body over to an El Camino frame so I was looking for the mounting points to draw up prior to moving the body itself.
