| | | Forums66 Topics128,022 Posts1,055,382 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | I have not been able to locate in any of the online manuals the location of the body mounts or pictures of the actual mounts. I was wondering if someone knows where that information would be. Thank you | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Jackyl, Have you removed the existing mounts or are they missing. They actually come with shims for final body alignment so if they are still there diagram the remnants. My rear shackle mounts had one shim on the frame (PS) and one on the cab (DS) the front mounts and the radiator also call for shims as required during assembly. You can see the shims in this photo: http://community.webshots.com/photo/2275285170102454676BEQvTZ
| | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | No still have them, but moving the body over to an El Camino frame so I was looking for the mounting points to draw up prior to moving the body itself.
