2 members (farmallb, Bill Hanlon), 133 guests, and 4 robots.
Topics128,266
Posts1,058,385
Members48,485
#458884 10/06/2008 3:43 PM
Are the sending units for the fuel gauge all the same for the 48 chevy's ? What my problem is,they only list one and i'm guessing it fits both under bed tanks and in-cab tanks but I'm not sure.I have the tank under the bed.
48 one ton,
While I don't know for sure, my guess is that the sender listed is for the conventional tank, in the cab behind the seat. If you have a tank under the bed, could it have been a special option, or more likely a feature added by some previous owner.
Stuart
atomarc #458893 10/06/2008 4:19 PM
No it's the original tank,there are not any holes in the cab for a in-cab one,and I remember reading someplace the 1 ton flat beds came with the under bed tanks.
It works part of the way up but then quits working at about 1/4 full.
Is there anyway to take the top apart to clean the contacts inside,I might be able to fix it if so.
48 one ton,
How interesting. I thought all the cabs had fuel fill holes and in cab tanks regardless of GVW. My 4400 has the in-cab tank.
It sure would be a first step to drop the tank and inspect the sending unit. Sometimes a cleaning and a little more tension on the wiper will make them work again.
That would also allow you to see it up close and determine if the one listed in the catalogs might fit.
Stuart
atomarc #458924 10/06/2008 5:21 PM
48 one ton & Stuart,
The gas tank was moved into the cab in 1949.
Tim
Tim,
Thanks, I'll remember that tidbit.
Stuart
