Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (jmoore, elhippie64, TooMany2count, DennisM, Phak1, ‘37ChevyPU, crenwelge), 131 guests, and 4 robots.
Topics128,282
Posts1,058,493
Members48,490
Has anyone mounted an original style oil filter to an Offy dual intake? The only brakets I've been able to find are for the beehive oil filter. Do not have an extra $225.00 plus laying around for the beehive. -- Thanks.
Go to the hardware store and get two u-bolts that fit around the intake. You might have to bend them a little to fit up to the filter.
Fred
52 3600
69 C-10
Junior Member
Junior Member
My Offy manifold has mounts for the stock filter but maybe not as only two of the holes line up but that's been enough for many thousand miles. Fred is right to shop for u-bolts. I have even found some square ones at NAPA.
