| | | Forums66 Topics128,282 Posts1,058,497 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#4585 09/20/2004 11:53 AM | Joined: Dec 2003 Posts: 103 Member | | Member Joined: Dec 2003 Posts: 103 | Has anyone mounted an original style oil filter to an Offy dual intake? The only brakets I've been able to find are for the beehive oil filter. Do not have an extra $225.00 plus laying around for the beehive. -- Thanks. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Go to the hardware store and get two u-bolts that fit around the intake. You might have to bend them a little to fit up to the filter.
Fred 52 3600 69 C-10
| | | | | Joined: Jun 2003 Posts: 41 Junior Member | | Junior Member Joined: Jun 2003 Posts: 41 | My Offy manifold has mounts for the stock filter but maybe not as only two of the holes line up but that's been enough for many thousand miles. Fred is right to shop for u-bolts. I have even found some square ones at NAPA. | | |
