| | | Forums66 Topics128,088 Posts1,056,124 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | When I push the brake pedal on my '49 1/2-ton and then release it, I hear a loud "clunk"! The cause is obvious. The flat metal bar that connects the brake pedal to the master cylinder assembly (located inside the engine compartment) is striking the firewall when the pedal is released. So, my question is, is the brake supposed to sound this way, or am I missing some sort of rubber pad to dampen the noise?? | | | | | Joined: Jul 2006 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 79 | Yes, there is a piece of rubber that wraps around the clutch arm link. It only costs $1. It is supposed to hit the firewall and eliminate that clunking sound you hear. It looks like this: http://www.classicparts.com/1947-59-Clutch-Arm-Stop-Bumper/productinfo/90%2D621/ Bluedawg
Waitaminute, you said brake arm not clutch arm. I don't think the brake arm has a rubber pad like this. There should be some adjustment at the master cylinder so the brake pedal doesn't have that much travel...
Nevermind I'm going to bed.
Bluedawg
God fearing, Gun toting, Constitution loving extremist.
| | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | Cool. How is the rubber attached to the linkage? Does it go all the way around the flat metal bar? Thanks. | | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | Got it. Ignore my last post. Thanks! | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | That is part of the charm of driving an AD, the clunk when the brake pedal is released. | | |
