6 members (1955 1 Series, 50Chevy3100, RdsLessTaken, DadsFirstPickup, tclederman, 1 invisible), 172 guests, and 3 robots.
Topics128,107
Posts1,056,225
Members48,436
#458373 10/04/2008 4:04 AM
When I push the brake pedal on my '49 1/2-ton and then release it, I hear a loud "clunk"! The cause is obvious. The flat metal bar that connects the brake pedal to the master cylinder assembly (located inside the engine compartment) is striking the firewall when the pedal is released. So, my question is, is the brake supposed to sound this way, or am I missing some sort of rubber pad to dampen the noise??
Yes, there is a piece of rubber that wraps around the clutch arm link. It only costs $1. It is supposed to hit the firewall and eliminate that clunking sound you hear. It looks like this:
http://www.classicparts.com/1947-59-Clutch-Arm-Stop-Bumper/productinfo/90%2D621/
Bluedawg
Waitaminute, you said brake arm not clutch arm. I don't think the brake arm has a rubber pad like this. There should be some adjustment at the master cylinder so the brake pedal doesn't have that much travel...
Nevermind I'm going to bed.
Bluedawg
God fearing, Gun toting, Constitution loving extremist.
Cool. How is the rubber attached to the linkage? Does it go all the way around the flat metal bar? Thanks.
Got it. Ignore my last post. Thanks!
That is part of the charm of driving an AD, the clunk when the brake pedal is released.
