4 members (baldeagle, Jon G, Oswald, 1 invisible), 57 guests, and 3 robots.
Topics128,015
Posts1,055,334
Members48,419
#458292 10/03/2008 11:07 PM
On my 3100 I interpret the 12v+ path to travel from the dash light switch to and thru the hi-beam switch and then on to the sealed beams. MY question concerns the function of the hi-beam switch. When activated, does the hi-beam switch re-route the 12v+ to the (high) element and switch off the low element or add an additional voltage to the high element and allow both elements to burn?
Next question, when viewing a sealed beam from the rear, 3 contacts are visible,when held in a manner that has 2 vertical contacts at the 9 and 3 o'clock position and a Horizontal contact at the 12 o'clock position, Is the horizontal contact the negative contact?
tools94 #458313 10/04/2008 12:20 AM
3B Offline
Hy tools94, yes the dimmer switch redirects the input voltage from the light switch to one of the two filaments in the sealed beam, both filaments are not on together. The way you describe the terminals, if my memory is correct ground is 9 oclock, if my memory is bad, someone will be along to correct my statement, hope that helps.
3B #458435 10/04/2008 2:08 PM
Thanks. I've discovered the switch is NG
