7 members (HandyAndy, 68ironhead, Rexville48, walter74, 6inarow, GMCJammer51, 1 invisible),
80
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,567 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | I know there is probably 100 answers to this question but what type of rings do you like to use in your Chevy 6 engine? The last one I rebuild I used Hastings Cast Iron rings and Celvite rod, main and Federal- Mogal cam bearings they lasted 18 years in my 261 cu. driven everyday to work with regular oil changes and replacement filters. Now the last couple of years I had to step up the grade of oil but still had reasonably good preasure for being wore out. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The old critters were built with cast iron rings and I don't suppose you are complaining about 18 years of service. Some of the later rings are hard to seat. If you are not out of high performance, why change? | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | as did I hastings http://www.hastingsmfg.com/and clevite Celvite rods & mains
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | Oh never complain about 18 years of service with cast rings. I pulled down the 261 the other day and had 4thousands taper in the back cyclinder. Looks like I can clean her up and go again with a new cam and rings,bearings etc. 62Blue Don
