| | | Forums66 Topics128,023 Posts1,055,371 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 382 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 382 | This Saturday coming up, I'm headed to Salina, Ks(from Omaha)to pick up a roller frame to switch my 3/4t to a 1/2t. What I'm trying to figure out is, can I use a car dolly hitched to the ball mounted on the rear bumper of my Brother's '85 Chevy truck, or should I get it up on a regular trailer & bring 'er home that way? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I don't see any problem pulling a bare frame that way if the tires are not weather worn. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Yup I SECOND that, the tow dolly on the bumper ball should be fine ...if possible to have a spare tire along would be a great addition to the haul incase of a blowout on the towed frame. Tim | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Guys, does the dolley have insurance on it? In our jurisdiction, the dolley must be insured on its own when being towed empty, if it is loaded the load must have insurance on it, either regular plates/tags, or a permit. Please check into what is required in your area[s]. If a trailer is available, I would use that to transport, just my preferrance. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | dittos on the spare.i'd take a couple if available.or get a couple rims you know will fit and put a couple decent used tires on them,my .02...............dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Jun 2006 Posts: 382 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 382 | Thanks, guys. One little detail I forgot to mention...the trans is still hooked up to the torque tube. Would it be best to unbolt the trans & take it out so we dont get the rpm's up(on the old drivetrain)while heading down the I-state?
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I would definitly take the trans.out.Also there are a lot of things to consider here.like tail and stop lights. My suggestion would be to check with your local State Highway patrol for what the requirements are for towing a vehicle,or in this case a part of a vehicle.I think it would be better to ask the proper authorities than to risk paying a big fine.And although a lot of people here are more than willing to give you suggestions,they wont help you a bit,when them red and blue lights are flashing in you rearview mirror.Just another suggestion.
| | | | | Joined: Jun 2006 Posts: 382 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 382 | True enough, Dale. Is it very hard to take the trans loose from the torque tube? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I would use a trailer if possible. You don,t know the condition of the wheel brgs & drive shaft brgs. A set up like that is not safe at high speeds. Like Dale says you will need some aux. lights to put on it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2006 Posts: 382 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 382 | I'm beginning to think that a trailer is the best route...thanks alot for all the help & input everybody...much appreciated! | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | I've done both over the years, and prefer a trailer. As mentioned, no need to worry about fixing up lights, condition of tires, etc. A trailer may cost a little more, but the peace of mind is worth it, I think. For me, if the trip is of any distance, a trailer is the way to go. Samantha | | | | | Joined: Jun 2006 Posts: 382 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 382 | Thanks, Samantha. Well, luckily, the fella I sold my trailer to(long story  ), said that I could borrow it @ no charge. Now, I just need to find a reliable truck to tow the trailer...may have something worked out on that, though...  | | |
