3 members (TS3600, klhansen, 1 invisible),
100
Mod | | | Forums66 Topics128,166 Posts1,057,012 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 59 | Hello All, New to the forum here and this past weekend I just picked up a 1957 Chevy 5100. I had my eye on this truck for months visiting it every time I went to my wife's parents house out in middle of nowhere Kansas. Finally got ahold of the farmer, thanks Father in Law, struck a deal and picked it up. It is an old grain truck minus the grain bed, complete and looking all original. Rust damage is limited to a few holes on the lower rear of the drivers side of the cab, some dents and dings but a pretty darn solid truck. 283, 4speed, 2 speed axle. Wow she rides rough. Are there any parts out there for these trucks? Specifically I need good Drivers side door hinges, battery tray and holddown, hood latch mechanism, a and chrome hood emblem. The bungies holding the hood shut have to go. http://community.webshots.com/user/teamja2Ryan | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | If it is a regular cab, not a low cab forward, all the stuff you mention is the same with a pickup and are readily available. And yes, they do ride rough. | | | | | Joined: Sep 2008 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 59 | I'm working on a link to pictures and it is a LCF not a regular cab. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | A 5100 is the shortest wheelbase of the Medium Duty LCF's. The other two wheelbase series designations are the 5400 medium wheelbase, & the 5700 long wheelbase. The '55-'59 LCF's were neat trucks. I owned two of them once. A '55 5400 series, & a '56 5700 series. Check out, http://www.classiccoe.com/oldcoetrucks/5459.htm | | | | | Joined: Sep 2008 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 59 | Are there any sources of new or reproduction parts for these trucks or should i be looking for used? Specifically
Door Hinges for Drivers side Hood latch mechanism battery hold down tray Hood emblem
Thanks, Ryan | | | | | Joined: Jun 2006 Posts: 382 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 382 | | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Ryan, Any parts specific to just the LCF's are going to be hard to find and are not in reproduction. Interior parts and glass will be the same as the pickup's. Door hinges are not the same as the conventional cab, if they are just worn out you can buy new pins and bushings and rebuild them. The hood embelem is also not the same, the LCF's have less Vee to the front of the hood making the emblem flatter. I have lots of general spec info on my web page...check it out in Mike's Garage! Mike B  | | | | | Joined: Sep 2008 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 59 | Thanks all and nice website Mike.
Do you know if the hood latch mechanism is the same as a conventional pickup. The bungies got to go on the big truck.
ALso, where should the VIN plate be on the truck?
Ryan | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Ryan, Hood latches are not the same as pickups. The vin plate should be on the drivers door hinge post. It is also stamped on top of the frame rail, drivers side near the steering box. Mike B  | | | | | Joined: Sep 2008 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 59 | Well truck is rewired, carb overhauled, heater hoses replaced, and getting ready for the 200 mile journey back to KC. I am thinking in 2 weeks or so weather permitting. Just waiting on tires at this point, bought 2 but still need 4 for the back. Also have to greese the chassis and we are set I hope... | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Sounds like a "winner". Back when I sold my '56 Chevy 5700 series LCF, the new owner, & a buddy of his, hitch hiked to North Carolina, from Marthas Vineyard Mass., & drove the truck home, with no problems. | | | | | Joined: Jun 2008 Posts: 28 Apprentice | | Apprentice Joined: Jun 2008 Posts: 28 | Nice looking truck Teamja2, my hood latch didnt work on my 55' 6400 but after some penetrant and use it started working again. My truck sat for 19 years but none of the parts have turned out to be broken (except the entire brake system). They built em right for heavy use back then. Best of luck to you on your trip. I would advise checking out the gas tank for rust as that made mine very unreliable, though an easy fix. | | | | | Joined: Nov 2004 Posts: 2,421 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,421 | Very nice, what a great find!  John
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | |
