1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#457114 09/30/2008 1:12 AM
Hello,
This is my first post to the forum so I apologize if its posted in the wrong place. I just purchased a 1951 3100. I am wondering what the best way to drain the gas tank would be. The tank is in the original location behind the seat. Is there a drain cock or anything on the tank?
Thank you for any information that you can provide.
Sincerely,
Chris
There should be a drain plug under the cab where the flex line connects on. There may be an el or a petcock there. Be careful when you take the plug out and hold the petcock securely. There is about a 2" long brass nipple that goes into the tank, and it is easily broken.
yeah,what he said.welcome to the bolt.where you from in ohio?...............dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
