0 members (),
83
Mod | | | Forums66 Topics128,081 Posts1,056,318 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45700 06/01/2005 10:51 PM | Joined: Mar 2005 Posts: 9 Junior Member | | Junior Member Joined: Mar 2005 Posts: 9 | Hey guys
I know its not an L6, but i thought maybe i could milk your expertise anyways. I recently finished a total rebuild on a GM 2.8 V6 to put in my Chevette(the winter beater when the truck's away)A milodon High Volume oil pump was installed along with a new RV cam and lifters. I got the valves all set up and the motor was running fine. I get around 70 PSI when I fire it up, and it runs nice and quiet. However, within 10 minutes, the pressure has dropped to almost 0 and the lifters are clacking up a storm, and power falls off quite a bit. What gives? did i screw things up by adding a HV pump? Did i maybe leave an important bit off when i put everything back together? I know my oil pan got a little ding (a 1/4 inch deep at most) in the bottom-could that have dislodged the pickup? im at my wits end, and praying that someone elses experience may save me tearing down my fresh motor. Thanks! | | |
#45701 06/02/2005 12:24 AM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Maybe the pump is starving for oil if it is made for a larger pan capacity. Just a thought.
Pressure is one thing but volume is quite another. | | |
#45702 06/02/2005 1:39 AM | Joined: Feb 2004 Posts: 29,825 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,825 | I've never seen a Chevette with a V-6! Is that an add-on engine, or do they do things different up there? :confused: :confused: :confused:
The early 2.8's such as the one I rebuilt from my Brother's Chevy Cavalier had chronic oil pressure problems, and among other things, we found an oil passageway from front to rear drilled off-center which was starving one of the main bearing journals for lubrication. He had bought the car with a bad rod bearing, and we drilled the passageway straight with an extended-shank drill bit, and installed a high-volume pump. No problems for the next 100,000 miles!
It sounds like you've got a major pressure loss somewhere, either a sticky pressure relief valve in the pump, or some other catastrophe. Pull the engine and dismantle it before you have a major failure, and look for oddball things like oil passage problems. The early 2.8's were not good engines! Jerry
#45703 06/02/2005 10:07 PM | Joined: Mar 2005 Posts: 9 Junior Member | | Junior Member Joined: Mar 2005 Posts: 9 | I got the 'vette with a 4 banger and yanked it for the 6, although GM did make a few in the early 80's for testing (never made production cos they were faster than corvettes!) I got the motor second hand and one of the rods had actually come undone about 1/2 an inch, making for a nasty knock and a cracked crank. I dont know the previous history of the motor, so i dont know about the proper pressure to begin with. getting to be very sorry i invested so much $ and time into such a turd...a buick 3.8, thats the way to go! | | |
#45704 06/02/2005 10:10 PM | Joined: Mar 2005 Posts: 9 Junior Member | | Junior Member Joined: Mar 2005 Posts: 9 | oh yeah, the pressure goes back up with RPM, so i dont think im lacking oil in the pan, and im sure i got the proper pickup for the pan... | | |
#45705 06/02/2005 11:17 PM | Joined: Feb 2004 Posts: 29,825 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,825 | You've got a stuck relief valve. Yank it out, and either replace the pump, or do a mirror-polish job on the relief valve with a felt wheel and jeweler's rouge. Check the valve bore for scratches, also. Jerry
