8 members (WICruiser, Southerntruck, jaycoop, 42465967, 2-Ton, Shade Baby, Joe H, TUTS 59), 127 guests, and 2 robots.
Topics128,129
Posts1,056,362
Members48,441
#45678 06/01/2005 9:23 PM
Junior Member
Junior Member
Can someone give me some information on the best/easiest way to change-out the rear-end gears or a compltete rear-end swap on my 53 3/4 ton. I would like to install gearing that is more user friendly on the highway. So far the only info I have came up with pertains to 1/2 tons.
Thanks, Mike
#45679 06/01/2005 11:07 PM
Mike,
I'm going through this right now. If you run a search here in the bulletin board under "Differential Swap' or "rear end" or something similar, you will find multiple threads discussing exactly this topic. If you have any specific questions I'll fill you in on what I've found so far.
#45680 06/02/2005 1:58 AM
search here for Eaton - that should bring up plenty of info. grin
1954 GMC De Luxe COE
#45681 06/06/2005 10:50 PM
Junior Member
Junior Member
I put a GM "corporate" 14 bolt from a 74 suburban under my 53 1 ton and the mounts actually all lined up! The only thing is, trackwidth was wider, so my truck looks a little odd...maybe if you were doing a frontend swap tho...
