| | | Forums66 Topics128,127 Posts1,056,671 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 66 | I was wondering if there is an adapter for this swap that allows you to use the enclosed drive shaft on 54 1/2 ton chevy if i have a later model motor(58-61)235. Plus does anyone know what the ratio on the stock rear end is? | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Don't know of an adapter for what you want to do, maybe someone else will chime in on that one. The '54 1/2 tons had a 3.90:1 gear. You can check it out yourself by using the tech tips link above and clicking on "Old Online Chevy Manuals", then go to the Restoration Packs/Specifications section for your vehicle.
Good luck on your project. | | | | | Joined: May 2008 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 66 | ok cool-I have heard of these adapters but never seen one. Alot of the hot rodders that use new trannys with old rear ends use them. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | With as many late model differentials available with relatively low mileage, you might be way ahead to just open up the driveline. The T5 swap is not rocket science and the open driveshaft/differential is just a natural progression. I've got pictures and documentation of the process in my webshots album. Check it out and see if it might be something that would work for you.
Dave | | |
