13 members (Otto Skorzeny, Gdads51, TUTS 59, Jon G, Joe H, HandyAndy, greenie-reddy, Simso, 1955 1 Series, Southerntruck, Gib70, 3B, 1 invisible), 123 guests, and 1 robot.
Topics128,103
Posts1,056,183
Members48,436
just fitted a 3" drop axle and disc brake conversion to a '58 1/2 ton apache. Regarding wheel alignment what is the ideal amount of toe in that I need to set?
Willy
1959 Chevy Apache
1948 Chevrolet COE
Trucks are like womens handbags !! you can never have enough of them and they can carry all your worldly possesions
kiwiwilly,
A typical setting would be 1/8"...this is 'toe-in'.
Stuart
Spec calls for .13 - .22"
This is an easy DIY project. This is how I did mine:
1. Cut 2 pieces of angle iron to the same length as tire dia.
2. Drill 2 holes in each piece to mount them to your drums.
(center line of hub should be in middle of the angle irons)
3. Measure the spread at the rear and compare to the spread
at the front.
4. Adjust the tie rod to bring them into spec.
Or, take them to your friendly alignment shop, but then,
I've got more time than money!
thanks guys my guess of 1/8 toe in was right. Just needed to confirm that.
Willy
1959 Chevy Apache
1948 Chevrolet COE
