0 members (), 162 guests, and 4 robots.
Topics128,089
Posts1,056,441
Members48,443
#456327 09/27/2008 5:55 AM
I have watched Chevy/gmc trucks over the las 20 years and my favorite is the 62/3 burbs for a family hauler. how many were made? I'm thinking I'd like to find a decent driver.
Devin
If you can't hose it out it ain't a truck
55 3100
63 Corvair Monza
64 El Camino
72 240Z
01 Suburban
They are plentiful, but try and find one that isn't rusted. I like the GMC'S, they offer a little different style and are harder to find.
Here is one of my favorite ones. 1963 GMC SUBURBAN This one sold about two years ago and is in Sweden.
This is a well done web page with plenty of build pictures.
Apprentice
Apprentice
i'm currently building a 63 panel and a 62 custom cab. my opinion also that 62-63 were the best years. you can find them but parts for panels/burbs are hard to get-but worth it. Ive had to replace most of the metal on my panel just to make it decent. worth the work since i paid zero for the panel and do all my own work ?'s [email protected]
Go for the '63. I've got a '62, and absolutely freakin' love it, but the torsion bar front suspension is a wallet killer, as is a dual reservoir master cylinder conversion thanks to the hydraulic clutch. I also don't care for the '62 grill--it looks like an afterthought; they tool the twin headlight '60/'61 grill and just stuck a big cyclops headlight in the middle of it. The '63 grill is much better looking for the single headlight, but I like the '60 grill better with the twin headlights, and have added one to mine (I'm also going to add the twin-cowl hood with '61 park lamp inserts).
The '63 used a coil spring front suspension, which is easy to get parts for or convert to later discs by swapping in a whole junk yard cross member. Power steering is easier to add, and it has mechanical clutch linkage so there isn't anything to get in the way of the dual reservoir brake conversion.
They also started using the Truck 12-bolt in '63, which is easier to get parts for (though my '62 has the optional Dana 44, which is even easier and cheaper to get good parts for as it's still in production today).
As a little detail, the '60 and '61 instrument clusters could be had with full gauges, rather than idiot lights, and the '60-'61 kick panel vents were cable operated with knobs mounted under the dash. I like those better, and added them to mine as well. If you do, you'll need to add a notch to the kick panel for the cables to pass through.
If I had it to do over, knowing what I do now I'd look for a '63, but I wasn't really looking for a Suburban--it found me. The wrap-around windshield and knee-knocker cab is what does it for me.
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
I've been working on a 63 GMC gov't 4x4 burb for 4 years now and love it. Had lots of help from this site. Like the front end!
