4 members (artinva, Shaffer's1950, Chip O, Rich'sToys), 113 guests, and 2 robots.
Topics128,072
Posts1,055,903
Members48,429
#4557 10/27/2003 8:52 PM
Ok I did the engine swap out last weekend and everything seems to be ok except for a high idle. The carb has been adjusted every which way you can think of and it still wont go below 1100. Also if it has run for a bit and you turn it off it still trys to run. Any ideas?
#4558 10/27/2003 9:24 PM
I was going to suggest a vacuum leak or stuck vacuum advance until you said it's dieseling when hot. You're likely getting gas leaking through the carb where/when it shouldn't. Rebuild or replace the carb, check the advance, and make sure all the vacuum lines are closed.
When was the last time you changed the fuel filter?
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#4559 10/27/2003 11:36 PM
Vacuum leak at the brake booster??
If the engine is running to hot and lean from a vacuum leak it will "diesel" when shut off.
Also check throttle plate inside the carb to see if it IS closing all the way...
#4560 10/28/2003 1:50 AM
Temp says its at 190. Not sure about any vacuum leak. Will check the throttle plate and post back.
#4561 10/30/2003 7:40 AM
Ok heres the latest. I checked all of the hoses and found no problems. I found a bottle of carb cleaner and gave it 2-3 shots. Waited 10 minutes, fired it up and after it warmed up then it started to die on me. A quick adjust of the idle and she is sitting nicely at 750-800. Whod of thunk it smile
