6 members (walter74, ndkid275, Dennys28, klhansen, Lightholder's Dad, Millenimech), 150 guests, and 4 robots.
Topics128,209
Posts1,057,462
Members48,471
Looking to put gas tank in bed of my 41 1/2.Looks like the 69 nova,with the long filler tub, will fit beetween the rails. My question is should i remove the rear frame rail so it could fit alot nicer? how much support, will i lose.Looking for any help. Thanks in advance.
Randy
1952 Chevy Suburban
1964 Chevy Suburban
1965 Chevy Suburban 4X4
1941 Chevy Truck
1948 Sedan Delivery
2000 K2500 Suburban
2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
This might not be the correct answer, but I dodn't think you want to remove any cross bracing on those frames. The frames are real flexible as it is and have a tendency to warp and twist
I am using a tank from summit. This tank will fit between the rear rails, behind the rear cross member. You can cut a hole in the middle plank and have access to the filler.
Summit Racing Fuel Cell
Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now.
http://www.coxcustomcars.com/
You can move the cross member. Probably should not REmove it!
~Jim
Thanks, so far. anymore ideas ad advice will help.
Randy
1952 Chevy Suburban
1964 Chevy Suburban
1941 Chevy Truck
1948 Sedan Delivery
2000 K2500 Suburban
2008 K1500 Suburban
I moved the crossmember in mine to give me some additional room for my tank. So far so good. I also agree with Big Chev, don't REMOVE it.
Robert C.
I'm a Genius in the making.
1950 3600
Have you looked at the following gas tanks as an option? I have seen nice installs and they would require no removal of crossmember (on my 46).
Give me a email and I will send you a picture of an install. Hovarth has good pictures of his but it is not in a deco.
High quality Ni-terne plated steel gas tank with 3-year warranty
Cost: 146.00
Applications:
Blazer (Full Size): 1973-81 31 gallon
Jimmy (Full Size): 1973-81 31 gallon
Suburban: 1973-81 31 gallon
Features: Small filler pipe, 1-1/4" ID, Depth of bottom half 5-1/2"
Capacity: 25, 31 gallons (depth diffences)
Dimensions: 28-3/4" x 28-1/8" x 12-3/4"
Free with Tank: Rubber O-ring and lock ring for sending unit
Packaging: Boxed
Part Number: GM-15A and GM-14A
cost: 146.00
http://www.quantaproducts.com/products.asp?dept=30
Cavebull
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
