0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | has anyone got any info on how to make SS shine like new money. thanks | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What kind of parts are you wanting to polish? There's really 2 good ways to do it1 is to get a good brand of metal polish (like Mothers) a pile of rags, and a whole lot o' elbow grease and work at ti (good for trim that's not in bad shape) 2 would be to buy/build a buffer and get the appropriate compounds(s). I have done both. I built my own buffer using an electric motor and an adapter arbor to mount buffer wheels on. You should be able to get the arbor, wheels, and compounds from any hardware store, farm store, Sears, and at swap meets. For the motor, again, hardware or farm stores, but they're kind of pricey. I scavanged mine off an old well pump, one from an old belt drive furnace blower would work too. Just wire it with a switch and a plug and you're set. Polishing isn't too hard, just takes some patience and a good grip on the part. Using a buffer is great for doing bolts and small parts, trip peices can be trickey, especially if the material is relatively thin/flexible. Easy to mess up a paice if you're not carefull. But it sure does a nice job. ou can make unpolished stainless shine like new chrome once you get the hang of it. Gloves are sugested (preferrably leather), as the parts will get hot, and the abrasives in the compounds can be rough on the hands. If you'd like, I can put some pix up of my homemade buffing machine.
Bill Burmeister | | | | | Joined: Nov 2007 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 80 | Check out Eastwood, they have all the stuff you need, | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | We used to just take a handful of plain dirt, not sand, and rub ss with it and it does as good as anything I have ever seen. | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | CW,
You must have different dirt than we do in SoCal. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | If you polish sheetmetal parts on a buffing wheel you better be extremely careful because the wheel can snag on something and pull the part out of your hand. Wear heavy leather gloves, pay CLOSE attention to what you are doing and go slow.
Back in the 70s we sent a thin stainless steel moulding that fits around the edge of a glass sunroof out for polishing. It was mounted onto a wooden fixture of sorts so it wouldn't get warped from the polishing. The guy doing the polishing put his head through the open center of the fixture, the moulding got caught in the buffing wheel and it cut his head off.
True, that's a bit extreme but just be aware that those things are not to be taken lightly. | | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Well I used to work in the auto parts business years ago, I have used many different polishes and creams from meguires and many other. The one I like the best is good old fashioned white tooth paste. Yep you heard me correctly plain old tooth paste. Laugh if you want but it works as good as anything else on the market and it is a whole lot cheaper.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Years ago, almost all toothpastes contained diatomaceous earth which is in most polishing compounds. Not all (not many) modern toothpastes contain this powder made from a sedimentary rock. | | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | True Buffing can be dangerous. I worked in a metal refinishing/motorcycle paint and repair shop. We had a guy come in who was a friend of the shop owner who wanted to polish his own primary cover for his bike and the wheel snagged it and sent it completely through the wall of the shop and out on the ground. He is lucky it was not his arm. I too made my garage buffer from a well pump motor. It works good enough but can bog down on big aluminum pieces. Keep an old junk screw driver handy to clean the rag wheels and always wear eye protection,wear an apron unless you don't care about your cloths turning black and a mask if you don't want your lungs black also.
Diatomaceous earth can be found in some farm/feed supply stores. I use it in my chicken coops to prevent lice and fleas. It is not that expensive. | | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | I had a older fellow at the Chrome shop tell me he uses Gold Metal Flour to polish his parts like trim. Infact he showed me the bag of flour. I used it to polish some scratches out of my Aluminum Radiator tank. Depending on how bad the surface is I have used 0000 wet or dry on some pieces along with super fine steel wool then flour. I am sure the flour will work on stainless steel also. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | I have some black dirt which we call gumbo and some washes with red clay in my pasture. Putting some of this in my hand and rubbing does wonders for GMC grilles and bumpers. I've been doing this for over 50 years. And yes, we probably do have different dirt than Southern California. | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | I polished all the stainless on my 55 Belair..neat how you can work it..bumped it a bit and sanded it, working up to 1500 wet. then buffed it through the different rouge colours.
Working those rear quarter spears was quite a challenge. Practice on old stuff for sure.
Caswell has good prices and supplies. | | |
