3 members (klhansen, dt235sd, 1 invisible), 67 guests, and 0 robots.
Topics128,049
Posts1,055,679
and are there stamping code pads on L6 engine blocks anywhere ? namely in late 60s*
thanks
Randy the easter wabbit !
-here to help fellow enthusiasts as best as possible grin
parting some vehicles, 54 ford truck 57, chevy 210, 69 fairlane coupe HT and others,
Go to http://www.inliners.org and hit Casting Numbers on the left hand side.
Paint & Body Shop moderator
The engine serial numbers or "dress" #s are stamped into a pad on the passenger side immediately aft of the distributor hole. You may have to shoot it off with some carb spray. I haven't had any luck posting my serial numbers and the casting numbers will only give you a range of '63 to '73, for instance. LMC Truck has a short list in their catalog of the 2 or 3 letter suffix codes and what years they correspond to. But I have a known '68 original L6 292 block with the suffix -XAE. Not on LMC's list, so it must be a figment of my imagination.
Every 25 years I like to rebuild that 292 just for GP
