| | | Forums66 Topics128,043 Posts1,055,611 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45595 09/08/2003 11:47 PM | Joined: Oct 2002 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 69 | and are there stamping code pads on L6 engine blocks anywhere ? namely in late 60s*
thanks
Randy the easter wabbit ! -here to help fellow enthusiasts as best as possible  parting some vehicles, 54 ford truck 57, chevy 210, 69 fairlane coupe HT and others, | | |
#45596 09/09/2003 12:00 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Go to http://www.inliners.org and hit Casting Numbers on the left hand side.
#45597 09/09/2003 10:30 AM | Joined: Jun 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2001 Posts: 85 | The engine serial numbers or "dress" #s are stamped into a pad on the passenger side immediately aft of the distributor hole. You may have to shoot it off with some carb spray. I haven't had any luck posting my serial numbers and the casting numbers will only give you a range of '63 to '73, for instance. LMC Truck has a short list in their catalog of the 2 or 3 letter suffix codes and what years they correspond to. But I have a known '68 original L6 292 block with the suffix -XAE. Not on LMC's list, so it must be a figment of my imagination.
Every 25 years I like to rebuild that 292 just for GP
