8 members (mason86, Ol'55, klhansen, Hotrod Lincoln, 32Fordpuchoptop, Ponchogl, Phak1, 1 invisible),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,676 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 82 Member | | Member Joined: Sep 2003 Posts: 82 | Ok I did the engine swap out last weekend and everything seems to be ok except for a high idle. The carb has been adjusted every which way you can think of and it still wont go below 1100. Also if it has run for a bit and you turn it off it still trys to run. Any ideas?
Thanks | | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | I was going to suggest a vacuum leak or stuck vacuum advance until you said it's dieseling when hot. You're likely getting gas leaking through the carb where/when it shouldn't. Rebuild or replace the carb, check the advance, and make sure all the vacuum lines are closed.
When was the last time you changed the fuel filter? | | |
#4559 10/27/2003 11:36 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Vacuum leak at the brake booster?? If the engine is running to hot and lean from a vacuum leak it will "diesel" when shut off. Also check throttle plate inside the carb to see if it IS closing all the way...
| | | | | Joined: Sep 2003 Posts: 82 Member | | Member Joined: Sep 2003 Posts: 82 | Temp says its at 190. Not sure about any vacuum leak. Will check the throttle plate and post back. | | | | | Joined: Sep 2003 Posts: 82 Member | | Member Joined: Sep 2003 Posts: 82 | Ok heres the latest. I checked all of the hoses and found no problems. I found a bottle of carb cleaner and gave it 2-3 shots. Waited 10 minutes, fired it up and after it warmed up then it started to die on me. A quick adjust of the idle and she is sitting nicely at 750-800. Whod of thunk it  | | |
