2 members (qside, 78buckshot),
76
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 18 New Guy | | New Guy Joined: Aug 2008 Posts: 18 | I have a 46 1.5T,it has a tach located just behind the fender on the drivers side.(RE:puzzled in N.C.in the big bolts forum)There is no cable presently attached to it.Where would I attach it if it were to be connected.This is a mechanical tach. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Mechanical tachs usually use a special distributor with a drive on it. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Mechanical tachs of that era ran off the rear of the generator. I have never seen one run off the distributor as was the case with early corvettes. The first 'vettes also ran off the generator so that is where I'd look. It isn't too likely that you still have the original generator with the tach drive and god help you in finding one. | | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | Well said by 53moneypit. If you find a cable and drive for the generator setup, you have to make sure the water pump and generator pulley sizes are correct, or the tach won't show the proper engine speed.
Harvester | | | | | Joined: Oct 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 67 | early corvettes up until '63 were generator driven tachs, 63 and later were distributor driven. I believe Eckler's corvette parts sells a replacement drive kit for those generators for around 150.00 might be worth the search... | | |
