3 members (Otto Skorzeny, Rusty Heaps, Steelonsteel), 108 guests, and 2 robots.
Topics128,034
Posts1,055,536
Members48,425
#455182 09/23/2008 12:42 PM
I got new oil filter lines from Chevs of the 40s,and the fittings where they hook to the filter are the wrong type.
They come with a flare fitting like a fuel line, and I need a brass flare fitting.
The filter is an original AC and the line has a part # of FT17.
It is on a 1951 216 engine,
Can anyone help?
A good hardware store or auto parts store should have brass adapter fittings (NAPA has a good selection and can order any Weatherhead-Eaton brass fitting). Your best best is to bring the hoses and canister to the store and have them match-up the fittings.
Do you need an adapter that has a T fitting for the oil pressure line (usually where the right-side hose goes into the block)?
Also contacting Chevys of the 40's will probably resolve your problem too.
Drew
DrewP #455275 09/23/2008 7:55 PM
The lines should have an 1/8" NPT fitting on one end, and a flare fitting on the other. The reason is so that the line can be hooked up without having to twist the hose at least on one end. Your engine should have had the adapter fittings (one for each line) either on the block (that's where I've usually seen them) or on the filter housing itself. If you don't have it, then a trip to flaps is in order. Check out their brake line adapter fittings. Should be a 1/4" inverted flare x 1/8" NPT male fitting.
Bill Burmeister
