7 members (Opelika Tom, JW51, Crimson48, klhansen, 46 Texaco, ndkid275, Stan 58), 92 guests, and 1 robot.
Topics128,085
Posts1,055,969
Members48,430
#454651 09/21/2008 10:08 PM
My bellhousing is cracked on the right side. :mad:
Crack from back
Crack from inside
Bellhousing full
Is this something that can be welded/repaired or do I have to find another one? And if I need another one, does it have to be this exact part number? Thanks for any assistance.
Give me my Truck, or...my truck daamit! Cause i aint leavin without it!
http://picasaweb.google.com/jadefalcon1218/MyK10
Riding in the Passing Lane
They can be welded but that is such a common one that it would be better to find a used one. Any v-8 55 to 72 or 6 from 63-72 with the large flywheel will fit. Except 68 up with 4 speed has a larger center hole. A few back in the early 60's had the clutch opening on the right hand side.
1972 Chevy c10 Cheyenne Super
Thanks Wrenchbender Ret.,will check local yard tomorrow. Got three days of vacation left to get this motor in, and lost a whole day. cry At least I have a good chance of picking one up tomorrow. Thanks again.
if all else fails no problem welding it with some nickel rod just drill a small hole where the crack end's and vee it out good !
Well I thought I found a replacement at my local yard. Looked ok when i put them both together. NOT! Paid $45 for an adornment. (no cash on return, trade or credit only.) :mad: Might have found one in CA. He is double checking the casting numbers for me. This time I want a guaranteed fit. Guess I'll just have to try and enjoy the day. (Would rather be enjoying my truck!).
old dog, Would rather not just weld as I am putting in a 430hp v8 with a lot of low end torque. Prefer not to do this all over again. I am a real Rookie, and and while I am thoroughly enjoying myself, I HATE to do something twice when i could have done it right the first time. grin
Your bellhousing looks like it's missing a good sized piece where the crack originates.
I sent you a PM.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
OlBlue, that is actually a factory cutout. Think i might have found an all new after market part on Jeg's. Now I just need to know what transmission I have. Could any of you give me an idea?
Most likely, it will be an SM420, if it still has the original trans.
Bill Burmeister
Would that be by Muncie, Borg Warner, Saginaw? Sorry, really am new to all this. blush
None of the above. It would just be an SM420 GM truck 4 speed, manufactured at the Toledo Transmission plant. Used from '47-'66. Should have the small bearing retainer on the front similar to the SM318/319 3 speeds.
Bill Burmeister
give me a minute, and I will grab a photo.
Ok, it will be longer than a minute. The battery on the digital is dead. dang
Ok, here are the photo's,
Passenger side
Driver side
Top
Would definitely help to know what it is. Thanks.
OK, now the waters are getting muddied a bit. That's not the original trans. Looks to be an SM465 (you can tell from the PTO port on the divers side), which replaced the SM420 in '67. In some ways, it's a better trans in that it is full syncro, rather than syncro in 2-3-4 like the 420. However, it doesn't have as deep of a first gear ratio. It will have the later large diameter bearing retainer, which will make a difference on the bellhousing. You will need a bellhousing with the large index bore.
Most likely, it came out of a 2wd truck, as the 465 was never used with a divorced style T-case.
Bill Burmeister
So do you think something like this would fit?
Summit bellhousing
Well it looks like OlBlue has come to my rescue. Has what I need, crack free and ready to go. Not only that, but he is close enough for me to drive out and pick up. I get the part I need, and the chance to meet a fellow Bolter! Outstanding! dance
Waved a smiling Don's 65K10 off towards Oregon with the correct bellhousing about an hour ago. He should have that engine in by 4:30 or 5:00 this afternoon thumbs_up
Always fun to meet another Stovebolter and compare projects. grin
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
OlBlue #455319 09/23/2008 10:31 PM
Just in now, and might take me just a touch longer than 4:30, (gotta give the paint a chance to dry). Many thanks to Olblue, you have a lovely home, beautiful shop, and more projects than I could ever handle! The little blurb on his signature, "No Room Left in Shop", believe it! Was great to meet another Bolter, and especially nice when it is one as helpful as yourself. Thanks again Olblue. grin Now off to work! (On the truck that is!)
No big deal, just a bit of trivia. The SM465 is not syncro in first gear either. It is a more rugged trans.
It's in!!! dance Still have to hook up all the wiring and incidentals, but It's in! Photo's for those interested. (will probably post them in separate post in general truck talk, but for those who have been following this...
Motor 1
Motor 2
Motor 3
Motor 4
motor 5
Can't wait till I get to hear the rumble! grin
And thanks again to all those who have assisted. It is greatly appreciated.
