Brrrr
place holder
0 members (), 75 guests, and 1 robot.
Topics128,274
Posts1,058,431
Members48,489
What is the best way to clean carbon out of combustion chambers?
How did all this sawdust get under the hood?
There are some pump gasolines (Exxon and BP, I believe) which claim to have additives that will clean up carbon valve deposits. Whether or not this is true I haven't verified. Maybe be worth a try.
-ftyler
Water or nitrous!
Since most of us don't have nitrous handy, except maybe Luke, use water. Start and warm up the engine. Trickle a small steady stream of water into the carburator while holding the throttle at fast idle. I use a spray bottle. Do it until it starts to bog, then stop and let it catch up. Do it a few more times, then change the oil. You will see a big black spot on the ground by your tailpipe and the combustion chamber will be quite clean. Just don't use your garden hose, you will hydrolock the engine if you use too much water.
Paint & Body Shop moderator
Drive like you're mad?????? grin
Craig
I used to call it "An Italian tune-up". It is taking someone's car and driving it the way it usually doesn't get driven. Max out rpm in low gear etc.
54 3100 with 235
62 flatbed dump C60 with 261
Tony,
I knew an Italian kid who use to boast about his heritage and how they use to tune up cars.
Salute'
Craig
sorry guys I work on new cars for a living, you dont use water any more it leaves rough edges on the pistons BG makes a cleaner that is 2 part. Part one you slowly drip in the intake system about 1500 rpm till the can is empty, you put the second part in the fuel tank 20 gal per can
GM also makes a great top engine cleaner if you can find it.
if you are having problems on yor new fuel inj. car try cleanig the intake system,
they are finding carbon deposits on the back of valves cause problems
If you want to use water make it hot as possible and add ATF
warren,,, won`t the ATF contaminate the sensors on a newer car?
tree91,, what year vehicle are you working on?
What's wrong with just dumping a bottle of injector cleaner in your tank?
I second OldCarKook's question.
Craig
I am working on a '52 AD with a '62 235. I may just dump a can of B-12 into the gas tank at my next fillup. I know how great the B-12 carb cleaner is, so I assume that the gas tank version is good, too.
I have used a product called Sea Foam. Seems to work great, and got it at NAPA. Used it on my old International Scouts with good results.
Just follow the directions on the bottle. Run engine until warm. Pour down the throat of the carb unitl motor stalls. Wait 15 minutes, and fire her up. Smokes like hell, so make sure the wind is blowing in the neighbors direction.LOL.
Do a search at www.binderbulletin.org in the tech talk archives and you will probably find alot of info on it.
Brian
