7 members (32Fordpuchoptop, 3B, TUTS 59, Shardean, msmall, carbking, Bill Hanlon), 51 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#454574 09/21/2008 5:33 PM
V
V Offline
Hey All,
A follow up (with q's) from my wedding-picture-post in the General section.
In a nutshell, I got my 59 3200 on the road in time to drive to our wedding, and even be in the ceremony (and serve as a kegerator). It has a rebuilt 235, and I swapped on a new H/W 5200 from Langdon's.
There is no fuel filter. I know....but there wasn't one originally, and when I put the engine back in I was crunched for time and made a mental note to add one later. I guess "later" came and went.
It runs very smoothly, but not too long into the 40-ish mile drive to the farm/wedding-site, it started stumbling and cutting out. At first under a load, like going up a hill on the interstate, and by the end of the trip I could barely go 1/4 mile. I checked the points, and they seemed fine.
I've driven it maybe 50-60 miles since installing the engine and carb.
If I pulled over and idled for a minute, it would be fine for a little bit, until it was under a load again. The engine would make a sort of hollow, suction sound, akin to the sound the little sucker-tube the dentist sticks in your mouth.
Anyhow, the truck is still at the farm, and I need to go get it, and I'd rather drive it home than have to trailer it.
I plan on pulling the screen at the inlet to the carb and cleaning it, and adding a glass-bowl filter in-line. I'm curious, though, if it could be something other than clogged lines/carb.
Has anybody had a problem like this after adding a H/W?
Could the stock pump and lines not allow enough fuel flow to keep the bowl full under a load? (I did put a new fuel pump on.)
I don't know what the jetting is on the new 5200, that might depend on the original application, perhaps. But I've been reading up about re-jetting, and have seen some references to similar problems from the wrong jet sizes for an engine.
Any ideas, folks?
Thanks.
-tyler
1959 3200 Apache Fleetside
In the Legacy Gallery
Riding in the Passing Lane
What is a H/W 5200?
1972 Chevy c10 Cheyenne Super
V
V Offline
The Holley/Weber carb that Langdon's sells.
V
V Offline
What, no ideas?
V
V Offline
Well harumph, then! I took my question over to inliners, and they helped me out, thank you very much! wink
I would suspect that you're running out of fuel. Either you have a restriction in your supply lines or the pump is not working properly. If it will idle when you pull to the side of the road, it has enough volume to support that, then maybe a little more to help refill the bowl, but not enough volume to keep the bowl full at speed.
Devin
If you can't hose it out it ain't a truck
55 3100
63 Corvair Monza
64 El Camino
72 240Z
01 Suburban
