5 members (tclederman, Peggy M, Kilted54, Bucker, 66flea), 76 guests, and 3 robots.
Topics128,269
Posts1,058,404
Members48,485
#45442 10/03/2003 8:02 PM
My 235 with holley 390/fentons has a momentary hesitation when accellerating. I think its the accel pump cam. For those of you running the 390, what pump cam are you using and how do you have the carb set up?
thanks
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
Used 10.5 power valve, yellow spring, original cam (brownish.tan)on mine. After we got the lag taken care of the only way we could get all the plugs to burn clean (maybe some design flaw problem with the Clifford 6=8) was to install the two different type of plugs with a 4-2 split.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
Hey 56
Whats your vacuum at idle? I've got 15-16" at 700 RPM. I think I've got the 6.5" power valve, and red pump cam. Did the 6.5 run your motor lean on accel or what? Is your brownish tan pump cam using screw hole #1 or #2 on throttle arm?
thanks
chip
Vacuum running 17-18. Cam in hole one.
1956 Chevy 3100
