| | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45442 10/03/2003 8:02 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | My 235 with holley 390/fentons has a momentary hesitation when accellerating. I think its the accel pump cam. For those of you running the 390, what pump cam are you using and how do you have the carb set up?
thanks
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#45443 10/05/2003 6:59 PM | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Used 10.5 power valve, yellow spring, original cam (brownish.tan)on mine. After we got the lag taken care of the only way we could get all the plugs to burn clean (maybe some design flaw problem with the Clifford 6=8) was to install the two different type of plugs with a 4-2 split. | | |
#45444 10/06/2003 9:33 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Hey 56
Whats your vacuum at idle? I've got 15-16" at 700 RPM. I think I've got the 6.5" power valve, and red pump cam. Did the 6.5 run your motor lean on accel or what? Is your brownish tan pump cam using screw hole #1 or #2 on throttle arm?
thanks
chip
#45445 10/07/2003 2:09 PM | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Vacuum running 17-18. Cam in hole one. | | |
