| | | Forums66 Topics128,040 Posts1,055,475 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I went digging through the oil filter catalogs at the local farm supply store and found two different numbers for the oil filter on the 235. The only one that had a listing was Fram. It had a listing for cars and trucks. My engine is of the 58-62 vintage and is reportedly out of an El Camino, so I'm assuming I should use the car filter, right? Is there actually any difference between the two? Is one a higher capacity than the other? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | There would be no difference. By the way I recently found that FRAM is recalling certain High Performance filters, so stay away from any # preceded by the letters HP.
Drew
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There were 2 different filters used on those cars & trucks. The dealer installed ones were AC. The aftermarket was made by Fram. The quickest way to tell the difference is the AC uses a 5/8 wrench on the cover bolt & Fram uses a 7/8 & sometimes has a big wing nut. You must get the right cartridge even though they make replacements for the other brand. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | The 235 bypass canister filter size was the same for both cars and truck and fits both AC and Fram canisters. Fram# C4P Wix# 51100
Wix filters are generally better quality and available at NAPA.
216 bypass canisters were smaller and early 261 bypass were larger than the 235. Larger size filters need replacement less often. | | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | If you can't find the WIX at NAPA I can get one through AMSOIL for you.
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | |
