8 members (sron48, Uncles51, gswbbc, Hanks custodian, FAST55, 32Fordpuchoptop, Joe W, 1 invisible), 149 guests, and 1 robot.
Topics128,041
Posts1,055,479
Members48,424
#454286 09/20/2008 4:08 AM
I went digging through the oil filter catalogs at the local farm supply store and found two different numbers for the oil filter on the 235. The only one that had a listing was Fram. It had a listing for cars and trucks. My engine is of the 58-62 vintage and is reportedly out of an El Camino, so I'm assuming I should use the car filter, right? Is there actually any difference between the two? Is one a higher capacity than the other?
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Whitedog #454341 09/20/2008 2:34 PM
There would be no difference. By the way I recently found that FRAM is recalling certain High Performance filters, so stay away from any # preceded by the letters HP.
Drew
DrewP #454410 09/20/2008 9:53 PM
Riding in the Passing Lane
There were 2 different filters used on those cars & trucks. The dealer installed ones were AC. The aftermarket was made by Fram. The quickest way to tell the difference is the AC uses a 5/8 wrench on the cover bolt & Fram uses a 7/8 & sometimes has a big wing nut. You must get the right cartridge even though they make replacements for the other brand.
1972 Chevy c10 Cheyenne Super
The 235 bypass canister filter size was the same for both cars and truck and fits both AC and Fram canisters.
Fram# C4P
Wix# 51100
Wix filters are generally better quality and available at NAPA.
216 bypass canisters were smaller and early 261 bypass were larger than the 235.
Larger size filters need replacement less often.
On the road every day...
1952 Truck - 235
1948 Coupe - 261
On the road #460233 10/10/2008 7:33 PM
If you can't find the WIX at NAPA I can get one through AMSOIL for you.
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
