0 members (),
80
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 52 | I was working on installing a camaro rear in my truck when an ember from my MIG landed on the paper with all my alignment measurements and up it went. I am left trying to install the axle with no number for the wheelbase. I went to the tech tip page but I see no listing for a '49 GMC 1/2 ton long bed. Off hand I want to say that what I measured was 118" and change but this number does not match anything posted there. Anyone know what the wheelbase should be for this truck? | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jun 2006 Posts: 60 New Guy | | New Guy Joined: Jun 2006 Posts: 60 | I don't have the answer to your question, but you may try the guys at http://www.oldgmctrucks.com/. there is a section on the site that list specs. you may be able to find the original wheelbase info there.
Gary, Kelly, and Family
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | A FC-102 1949 model is 125.25" wb That is the long wheel base A FC-101 1949 model is 116" That is the short wheelbase. Does your bed have 2 or 3 stake pockets per side. If it is just 2, then it is the short wheelbase. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | If it is a long-bed half-ton the 125.25 is the correct stock measurement. But if you are changing rear axles I'd suggest you spend some time mocking it up at the desired ride height and then position the axle where it looks best.
Most of these trucks look like the wheels are too far forward and this is your chance to fix that!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | If we could ever add a forum listing the worst things that could happen while Bolting this would certainly be near the top of the list. I am reminded of the old cow stepping on her utter.
~Jim
| | | | | Joined: Jul 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 52 | 125 1/4 was the magic number. Goes to show how terrible my memory is. I swore it was 118. And, obviously writing it down did not help. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Not a fatal mistake! Just don't forget your wife's birthday!
~Jim
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | At least you didn't torch the whole truck!
