1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#453641 09/18/2008 2:57 PM
V
V Offline
I was working on installing a camaro rear in my truck when an ember from my MIG landed on the paper with all my alignment measurements and up it went. I am left trying to install the axle with no number for the wheelbase. I went to the tech tip page but I see no listing for a '49 GMC 1/2 ton long bed. Off hand I want to say that what I measured was 118" and change but this number does not match anything posted there. Anyone know what the wheelbase should be for this truck?
you should set the new axle at no more than 1.5 to 3 degrees tilt angle for proper driveline angles. you may wish to center the rear tire in the fender well. I moved mine back 2.5'' but probably should have 3''
good luck wink
http://www.iedls.com/ptsetup.html
http://www.dlssac.com/measureauto.php
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=587685-R1-048-22A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=Scan1_0001-1.jpg
Jim & Caroline
I don't have the answer to your question, but you may try the guys at http://www.oldgmctrucks.com/. there is a section on the site that list specs. you may be able to find the original wheelbase info there.
Gary,
Kelly, and Family
A FC-102 1949 model is 125.25" wb That is the long wheel base
A FC-101 1949 model is 116" That is the short wheelbase. Does your bed have 2 or 3 stake pockets per side. If it is just 2, then it is the short wheelbase.
If it is a long-bed half-ton the 125.25 is the correct stock measurement. But if you are changing rear axles I'd suggest you spend some time mocking it up at the desired ride height and then position the axle where it looks best.
Most of these trucks look like the wheels are too far forward and this is your chance to fix that!
If we could ever add a forum listing the worst things that could happen while Bolting this would certainly be near the top of the list. I am reminded of the old cow stepping on her utter. grin
~Jim
V
V Offline
125 1/4 was the magic number. Goes to show how terrible my memory is. I swore it was 118. And, obviously writing it down did not help.
Not a fatal mistake! Just don't forget your wife's birthday! grin
~Jim
At least you didn't torch the whole truck!
Paint & Body Shop moderator
