8 members (mk72, Gdads51, ShopRag, TUTS 59, Hush, Otto Skorzeny, Hugh63c10, Hanks custodian),
149
Mod | | | Forums66 Topics128,043 Posts1,055,524 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 20 Apprentice | | Apprentice Joined: Sep 2008 Posts: 20 | I am the fairly new owner of a 65 Chevrolet LWB. I bought the truck as a project. While it has had some modifications, i.e. 400SB, 350 auto, 308 RE, A/C and many other mods, most of the work done seems to be done improperly. The most recent problem I have not been able to correct is the steering. The front end has been changed and I can't identify exactly what it came out of. It has PS and 5 lug spindles. My local alingment shop has lined it up but a problem still exists that we can't figure out. When you turn the wheel all the way left or right, the front end gets in a bind and kind of drags sideways. When traveling down the road and turning normal corners, no problem. The local shop seems to think the geometry is off some how or another. He suspects the pitman arm or idler arm is the wrong length or possibly the wrong one all together. Short of changing parts at random, I'm not sure what to do. Any help out there? All advice would be welcomed. Thanks. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Boy Lee ya askin a ? I think will only be answered with pics. need some serious pics of the workins ...get some good shots of the whole steering sytem from underneath maybe some one here will notice something amiss?. you can get a Photobucket account for free all ya gotta do is go to the site an join..upload your pics and post a link here on the site. hope this helps Tim | | | | | Joined: Sep 2008 Posts: 20 Apprentice | | Apprentice Joined: Sep 2008 Posts: 20 | Thanks. I'll get some shots and post them. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | if you need, i can measure the idler or pitman arm on my 63 1/2 ton or 64 3/4 ton. | | | | | Joined: Sep 2008 Posts: 20 Apprentice | | Apprentice Joined: Sep 2008 Posts: 20 | Hey that would be great! I would think the 1/2 ton measurement would be more accurate.
Thanks! | | | | | Joined: Feb 2001 Posts: 198 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 198 | It would also help to know what was actually changed under there. Did they just swap spindles or other parts as well. I know on my '63, which should have the same parts as your '65, when I turn full stop left or right the outside wheel scrubs pretty hard like it turned too much. The only thing I have done is lower the front end by chopping the springs. Of course that changed the geometry some. Don't know if it did that at the stock height as the first thing I did when I got it home was lower the front.
Attitude - The difference between an adventure and an ordeal! Deja Moo - The feeling you've heard this bull**** before! '63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red' '69 or'70 or ? Mantaray DuneBuggy
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | This may seem overly simple but.....
If the inside of the tire is rubbing on the frame when you turn the wheel all the way it will give the sensation of dragging sideways. This can be corrected by different rim offsets or wheel spacers.
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | well i got down and measured the '63. the pitman arm looks to be about 5.5" from center to center and 7 3/8" overall lenth. the idler arm is not in a single plane it is offset a bit. so it looks to be 6.0" center to center and 7 5/8" oal. i had to break out the 18" calipers to try to measure it. don't hold me to those #'s but looks to be pretty close. lmc catalog shows same part #'s for 63 and 66. good luck, hr | | | | | Joined: Sep 2008 Posts: 20 Apprentice | | Apprentice Joined: Sep 2008 Posts: 20 | Hoggyrubber,
Thank for measuring. I'll check the length of mine and let you know how it turns out.
I appreciate your help. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | no problem. stuff changed like that makes me wonder why people don't just leave stuff alone. well i am guilty of botching up a thing or two. | | | | | Joined: Sep 2008 Posts: 20 Apprentice | | Apprentice Joined: Sep 2008 Posts: 20 | It appears that the spindals used to convert to disk brakes didn't have stops on them. The steering was turning too far which caused the tires to "scrub" sideways. We got it on the alignment rack and counted the steering revolutions, then compared it to another truck. It seemed to turn about 1/2 to 3/4 revolutions more than the model we went by. We checked the degree of turn (or radius) then built adjustable stops and welded them to the lower "a" arm. It's working pretty well now but could probably use a little more adjustment to stop it from turning quite so sharp. I think this solved the problem. The measurements that Hoggybubber gave me confirmed that I had the right parts, just someone that didn't have a clue changed parts without doing the job correctly or using the right spindals. Thanks for the advise. I'm sure I'll need more later.
Lee | | |
