| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45354 05/08/2005 12:33 AM | Joined: Aug 2003 Posts: 108 'Bolter | | 'Bolter Joined: Aug 2003 Posts: 108 | Gents,
I'm still troubleshooting my 235 problems... it seems to be idleing fine now, and even accelerating OK, but it will still run rough/ stall on acceleration or when I dump the accelerator. Even after running for 30 min to do valve tappets, it still hasn't warmed up to even 160 deg on my new SW water temp gauge. I'm wondering if I'm running too cool and maybe getting condensation of gas? Your tips have been very helpful so far, thanks a bunch guys!
Regards, Tyler | | |
#45355 05/08/2005 4:30 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Sounds like your thermostat is stuck open, for one. If you have the rochester carb it also sounds like the accelerator pump isn't working right.
Fred 52 3600 69 C-10
