4 members (Bill Hanlon, Wayne67vert, eclector, Otto Skorzeny), 92 guests, and 3 robots.
Topics128,034
Posts1,055,533
Members48,425
#452139 09/14/2008 12:33 AM
After waiting 6 months, I've got the sheet metal for my '50 AD at the body shop. I was reviewing the bedsides with the body guy and he showed me the holes on the rear stake pockets where the tail lights were mounted. He asked if I wanted these holes welded up. The holes are located about 1/2 way up the stake pocket.
It suddenly occured to me that I've never really noticed how the tail lights were originally mounted on a '50. I believe there was only 1 tail light. Does anyone have any advice on where the best place is to mount tail lights? I'm mounting lights on both sides.
I looked in the gallery and found several variations. Any advice or pics would be greatly appreciated!
It never costs more to ask and it never costs more to think big.
Orignally there was only one taillight and it was mounted on the drivers side. Check the pictures of Bolters here. You will see the original mounting place.
~Jim
There are the original mounting points like mine:
http://community.webshots.com/photo/2840056470102454676GYwdJM
These mount to the bedside as your bodyman noted. If you want two brakelights and turnsignals this is the "factory" look. There are lots of aftermarket brackets available from places like Jim Carter catalog page 66/67 Items number LGL204L and LGL204R. Also speedwaymotors.com have some.
Thanks for the pic and the info. I have the tail lights ready to mount when the bed gets painted. The truck came with 2 lights mounted about 3/4 of the way up from the bottom of the bed, a bit too high for me. These look like they were added sometime later in the life of the truck. The lights were mounted on the side of the stake pocket facing the front of the truck and I knew this was not correct.
Appreciate the feedback!
Mounting the lights high is not a bad idea even though it sure doesn't look good as original. Those little tail lights are so small and when they are mounted down low when most drives are conditioned to look for bigger and higher positioned lights.
Safety First
Just my 2 cents.
~Jim
Another reason to mount them up high is that if you use the original location the license plate gets obscured by the bumper.
Paint & Body Shop moderator
