0 members (),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45270 04/12/2005 5:35 AM | Joined: Jul 2004 Posts: 46 Junior Member | | Junior Member Joined: Jul 2004 Posts: 46 | IM not sure what tranny i have i forgot now but it is a 4 speed floor shift. When i shift to any gear i think i have to put the clutch in and let the rpms drop alot in order to not have the grinding noise, even then it still does it a bit. What does this mean. Syncros bad? | | |
#45271 04/12/2005 6:30 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Hopefully it's something as simple as clutch pedal travel. Cecil......... | | |
#45272 04/12/2005 6:35 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yeah, could be you need a clutch adjust, but could be worn syncros - try proper double clutching!
Bill | | |
#45273 04/12/2005 10:10 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | What year truck? Early 47 on back had no syncros. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#45274 04/12/2005 10:18 PM | Joined: Jul 2004 Posts: 46 Junior Member | | Junior Member Joined: Jul 2004 Posts: 46 | Well I know i need a new clutch and it is quite possible that the clutch isnt adjusted correctly. What do you consider proper double clutching? | | |
#45275 04/13/2005 3:22 AM | Joined: Mar 2005 Posts: 49 Member | | Member Joined: Mar 2005 Posts: 49 | Assuming you're pre '47 and the cluth adjustment is fine, you have to double clutch the non syncro trans. Run the engine to a moderate RPM, shift to neutral, let the clutch out while the RPM slows down, depress the clutch and ease into the next gear. Coming down takes a little more practice. While in neutral during the double clutch, slightly rev the engine, depress the clutch and drop into the lower gear while the engine is winding down. The trick is matching the engine RPM to the trans. Keep practicing and put a qt of Lucas in that trans. | | |
#45276 04/13/2005 4:08 AM | Joined: Jul 2004 Posts: 46 Junior Member | | Junior Member Joined: Jul 2004 Posts: 46 | nope i have a '64 C10. So it has syncros. I do know for a fact that i need a new clutch. The grinding has gotten worse recently. Do you have to adjust the clutch once in a while? I never have but i dont drive the truck much. | | |
#45277 04/13/2005 6:19 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, you need to adjust the clutch as the disk wears and maybe the springs weaken - prolly solve yer problem
Bill | | |
#45278 04/13/2005 6:22 AM | Joined: Aug 2003 Posts: 31 Junior Member | | Junior Member Joined: Aug 2003 Posts: 31 | If the clutch adjustment doesn't clear it up the problem could be with a contaminated clutch with oil or grease on the disk. This makes the clutch disk swell and not fully release. Clutches don't last forever, you may have to bite the bullet and replace the clutch assembly. Before you do anything drastic, check the trans fluid level. If the fluid is too low the synchros don't work as well and you get gear clash. Hope it's an easy fix for you.
I feel like I'm diagonally parked in a parallel universe.
