1 members (Hotrod Lincoln),
79
0
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Yes there is a small piece missing and it's hard to come by. One of our fine 'Bolter's, J Lucas, sent me a pair. You can barely make it out in this photo. Its located on the door trim, the second screw from the right. Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Thanks Don. I guess is off to the parts wanted section, with my fingers crossed. Cecil........... | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I believe I sent some of these to a fellow bolter. I'd attempt to form this tiny little strip from sheet metal, same shape as what you have but with a screw hole. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I had one and had to make one. They aren't hard to fab. It's just a 1/2" wide piece of sheet metal that you bend to the contour of the door frame. The hardest part is gettig that little roll at the upper edge. I used a 1/4" dia. rod to bend the strip around then, formed the rest to to match the door frame. The outside edge just tucks in between the door and the window track. Drill a screw hole and your done. Good Luck George | | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Cecil - I removed the trim piece and took some photos for your reference should you care to fab the piece yourself. You can scroll through my Picasa Door Album to see the details. Hope this helps. Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | I also had one and needed one so I made the second. Very easy to do as they only hide the seam in between the two trim pieces.
1946 Chevy Pickip
| | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I just bought & received a perfect repo set of these little covers from PHLOBE47 on ebay. | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Thanks to everyone, i think i will just go ahead and make a set. They don't look that tough to make. Cecil.......... | | |
