| | | Forums66 Topics128,154 Posts1,056,851 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | The generic Accy-Off-On switch sold for the foot stomp ignition is functional but ugly and does not fit right in the stock dash of my 59 1/2 ton. Does nobody make an original stlye for the foot stomp? What do you use? Is the stock regular key starter switch used by just using some of the terminals? Are used ones out there being used with success? | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Well, you could use the stock key switch, just don't connect anything to the START terminal. It will work fine. You could configure the start terminal to honk the horn or something if you wanted to give unauthorized drivers a surprise.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | i believe the replacement is sold buy napa number ech st33 echlin try this link http://www.napaonline.com/NOLPPSE/(S(bykoamjrya4tau45vc3bzx55))/Results.aspx?Ne=25000&N=599001+101959+50014+2014099+25015&Nao=10 | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The 6 cyl. switch and the V8 switch were different. As far as I know all the replacement switches are for the V8. I tried to find a repop 6 cyl switch for my '59 and ended up drilling the lock cylinder out and replacing it. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I'm running a re-pop V8 switch mith my 6, works very well. Bill, thanx for the idea on the "start" position! I've got a very LOUD old police car sirent that's just begging to be hooked up like that!
Bill Burmeister | | |
