8 members (Bill Hanlon, Jon G, 55shaker, Otto Skorzeny, HandyAndy, UtahYork, DadsFirstPickup, Hotrod Lincoln),
78
Mod | | | Forums66 Topics128,036 Posts1,055,448 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 79 | I didn't have any of the original linkages from the gas pedal or throttle cable to the carburetor, so now I'm designing my own. I want to use the throttle cable in the dash as a "cruise control", but I want the foot pedal to "overide" the hand cable in case I ever want to pass anyone. Any of youse got any pictures or stories to tell about how you accomplished this task? (Especially if you went with a different engine.) I'm using a 250 L6 in my '52. Thanx, Bluedawg
Bluedawg
God fearing, Gun toting, Constitution loving extremist.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Just a warning, using the hand throttle as a "cruise control" is illegal, as there is no safety to relaese the throttle nor is there a true speed control. This could lead to a runaway engine. Best bet would be to get a legit cruise control system with a speed sensor.
Bill Burmeister | | | | | Joined: Jul 2006 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 79 | rats, foiled again by the long arm of the law...
Bluedawg
| | | | | Joined: Aug 2006 Posts: 6 New Guy | | New Guy Joined: Aug 2006 Posts: 6 | | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | I remember trying to use the throttle knob as a "cruise control" on my '47 Chevy, back in 1955. It was not at all satisfactory, as it was nearly impossible to maintain a steady speed, and it was disconcerting to have to coordinate the brake pedal and hand throttle to slow down.
Hoyt | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Safety issues aside, the original configuration of the hand throttle does allow for gas pedal override.
The way it mounts is that the center of the throttle cable replaces the cotter pin that holds the accelerator linkage rod into the throttle lever on the carb. When you pull the hand throttle, it tugs the throttle open, but the rod is still free to slide on the cable end so if you floor the gas it still moves.
Another option is to run a short length of chain between the end of the cable and the throttle linkage to accomplish the same thing.
