0 members (),
136
Mod | | | Forums66 Topics128,193 Posts1,057,259 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | I have my SM420 being rebuilt-bearings, seals and replacing the top plate and shifter. The repair guy orginally wanted to replace all the gears because of water damage but I looked at them and it seemed purely cosmetic..so I put a hault to that. The gears had no damaged teeth etc.I called him to pick up the tranny and now he says he can't get some of the seals for the PTO-not that I was having any problems with it.He said he could re-machine something so a more common seal could be used. I told him just to put it back on and I'd pick it up..the bill has grown another $200 from what he originally said and I think I'm being milked.
Back to my question: Any sources for PTO parts-if needed-can new or rebuilt ones still be purchased?
Why do I have a PTO? My 55 2nd series came with a dump bed-regular step side..but it dumps...handy for dump runs.
Keith
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Keith,
You don't have to have a PTO unless you are going to use it. Block off plates can be found or made easily and 'problem solved'.
All seals are identified by ID, OD, width and lip style. There are bazillions of seals made and almost all are available somewhere. If you don't have a need for the PTO, block it off and deal with it later.
You probably aren't' being milked, the guy is doing it the only way he knows how, with the correct new parts. It's his reputation that is at stake.
Stuart | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Ya..I've thought about a block off..however I do use it..so I plan to try it and see what happens. I don't recall it leaking in the past. If it does then I'll block it-and search for parts..
I'll give some thought to what you said about his reputation..
Thanks Stuart,
Keith | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What brand PTO? If it's a Chelsea, parts are still available for them.
Bill Burmeister | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Don't know what it is Long..Just know its bolted to the SM 420-Did Muncie make there own?
Keith | | | | | Joined: Sep 2008 Posts: 16 New Guy | | New Guy Joined: Sep 2008 Posts: 16 | Hi, I am brand new and hopefully won't bore you guys with a stupid question, but here goes.
I have a 1941 chevy 1 ton dually that I just purchased. It has a 4 speed tranny. I would like to find a pto/hoist and bed for it. How can I tell if a pto/hoist/bed will fit? I saw an add for a 1950, pto & hoist. Will that fit?
Thanks for the help!
Jon | | | | | Joined: Aug 2005 Posts: 39 New Guy | | New Guy Joined: Aug 2005 Posts: 39 | Just know its bolted to the SM 420-Did Muncie make there own? Yes, Muncie made PTOs, but others did, too. If it's a Muncie, the oil seals are: - Timken 480821 or Chicago Rawhide 7474 - Timken 480889
Simplicity leads to reliability.
| | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Thanks Polarcat..I'll see if I can find a name on the PTO
I'll look those parts up. Small world I work for a metal stamping company that stamps seal inserts for both those companies.
Apreciate the help..
Keith
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Hi Slickriffs. The Muncie you may be thinking of is not the one who made the Muncie 4 speeds for the old Corvettes and muscle cars but is Muncie Power Products in Muncie, IN.
If you have an old Muncie PTO it will be a Chelsea A series if it's cast iron anyway. Muncie at that time was a catalog company who resold the products of many other true manufacturers and were very good at it. They are now a manufacturer of their own products. You should have no problem at all with the seals from them or locally for that matter. Fleetpride is the CT distributor and they have 4 locations. | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Thanks for clearing that up MoneyPit..I had some work done on the tranny recently and had the mechanic look at it. He found 2 of the seals but couldn't locate one of them..He got creative and used an O ring to repair the existing one..So far no leaks..
I'll need to turn my attention to what the PTO drives-the pump for the dump stepside..not sure I'll find any name on it.
Thanks again,
Slick | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | When you get to the pump part of the equasion e-mail me some photos of it. I may be able to help you out on identifing it and locating parts. | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Dave..that would be much appreciated..I'm in the garage today..the battery is charged in the camera..so I'll shoot a few pics..so far the only thing I've seen on it is the # 321..
Thank You Mr. Moderator
Keith | | |
