4 members (TooMany2count, frogfarmer, moparguy, 1 invisible), 55 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
By Randy Baumann and Dave "Koolkar" Feltner-Well written with exceptional illustrations..I was going to outsource this work but after reading this article I'll do it myself. The clearest instructions I've ever seen. This read was reccomended to me by Sid at DroppedAxles.com.
Well done..two thumbs up!
Keith
SR,
Are you going to post the link.
Here is the link
Kingpin tech tip
Thanks Lonnie for posting that.
Click the "PDF" download for the good stuff.
Keith
Denny,
There is a link to the PDF in the lower right hand corner.
All the links in that Tech Tip worked for me (all were the same pdf file).
jdl Offline
Yes, from personally meeting Dave Feltner(he got my truck home grin) he sure seems to know his stuff.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
Denny would you like me to send it to you in an email?
Jeff
My 1953 Chevrolet
1947.1 Gallery
I agree that the tech tip was VERY helpful.
However, the following did not work for me.
Originally Posted by kookar
I let the weight of the truck help push the old kingpins out. So far, it has worked every time
We got one out with a 12 ton press. It sounded like a shotgun when it busted loose. I couldn't get the second one and took it to a guy with a bigger press. It took 15 tons of pressure to pop it loose.
As a side note, I'm pretty sure that I was the first to replace them, they were worn extreemly bad.
while you're at it & have everything apart...
look @ this tip. It should work for almost any truck:
http://www.stovebolt.com/techtips/draglink_adjustable.html
Jim & Caroline
Thanks for the great tip on the draglink! I somehow missed that one. Very cool. cool
Jeff
My 1953 Chevrolet
1947.1 Gallery
Have seen that Tip Jim..Novel idea..I have a dropped axel I'm putting on..as well as Toyota power steering next year..it's unclear to me if I'll need to make adjustments to the drag link or pitman..The PS conversion includes a pitman.
You've done a lot of nice things to that truck.
Keith
