| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45081 05/12/2005 1:56 AM | Joined: Oct 2004 Posts: 3 Junior Member | | Junior Member Joined: Oct 2004 Posts: 3 | I've been having no look with my baby, she's really acting up. Anyway, thing of going with an electric fuel pump on my 250. I wanted to know if anyone ever came across thing item
http://www.jcwhitney.com/autoparts/ItemBrowse/c-10101/s-10101/p-100000211691/mediaCode-ZX/appId-100000211691/Pr-p_CATENTRY_ID:100000211691 | | |
#45082 05/12/2005 1:08 PM | Joined: Feb 2004 Posts: 29,744 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,744 | The standard mechanical pump will supply all the fuel the engine will ever need. Why mess with something that works, and spend 3 times the money to boot? Jerry
#45083 05/12/2005 3:39 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | You should attempt to diagnose the problem vs changing parts. Disconnect fuel line at the carb, run a hose to a jar and crank the motor. Should see plenty of gas. If that's ok it time to go through a tune up.
Get a shop manual and go through the tune up proceedures. You'll be money ahead and really find the problem. Just swapping out parts we called "Easter Egging" in the Navy. | | |
#45084 05/12/2005 5:57 PM | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | The electric fuel pumps have too much pressure for the Rochester and probably the Carter 1 bbl carbs. Mine would over power the float and run raw gas into the block. If you have a newer carb, Never mind. Ralph | | |
#45085 05/12/2005 9:17 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Check the fuel sender for obstruction, I have had a couple that were clogged at the sharp bend right where the line comes out of the tank. Gotta pull the sender out & fish it thru w/wire, seems air pressure won't do it. Brian | | |
