| | | Forums66 Topics128,022 Posts1,055,381 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | It seems that my starter is having fits. It stopped the other day while turning the engine over, so I got out, pulled the coil wire(just to be safe) and turned the engine over by hand, got back in and it started fine. Well, today it did it again, and it still won't do anything. So I pulled the starter and it had a bunch of oil on the contact surfaces of the housing(where it touches the flywheel and gets a ground. Could this cause it to loose its ground? And will another starter that I have (model 1107108) fit my flywheel? I researched it and the Chevs of the 40's site said that it will fit a '38 through '48. Is that it? It came off of the engine that WE b Old had in his truck. I measured the distance between the teeth on both one starter and the other and they both had the same distance between the teeth, this tells me that the replacement will work but I don't want to tear up the flywheel. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Well, I cleaned it all up, put it back on, and it just barely cranked over, then stopped. I messed with the battery cable and it finally started to work right, it seems that it had lost grip on the battery post or something. But can anyone still tell me if that other starter will work on my truck? | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | It looks like that starter should fit up to 1954. click here | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Thanks. Don't know what the deal was, I made sure that battery cable was tight on the battery post before starting it, and then it just quit, but take it off, clean it up a little, put in back on, it does the same, and then mess with the cable and it works great, it just doesn't make sense. Oh well, I'm not complaining, it works now. I guess I know that if one goes out, I can use the other.  | | | | | Joined: Jun 2006 Posts: 204 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 204 | JDL, I had a similar problem on my 65 Panel Truck, it turned out to be the battery cable. There was nothing wrong with it visibly, but we used a set of charger cables from the battery to the starter and it turned right over. Replaced the cable and no problems since, sttripped back the insulation on the old cable and about 6 inches backf from the tterminal end the cable was shot. Just a thought. Mike My old truck's still running good, my ticker's ticking like they say it should, I got supper in the oven, a good woman's loving, and even my bad days aint that bad...Yeah, I'm a lucky man! 1953 Chevy 3100 Shortbed1965 C-30 Panel Truck 1963 C-20 Long/Fleet Pick-up California Black Plate
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | battery cable can cause you a lot problems and lead you astray.. I know that for sure..
the other starter should work but might cause your truck to run hot.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Joker, can you elaborate on that starter causing the truck to run hot? I've been contemplating changing out the battery cables to a heavier, cable set. What gauge should I get and how long should they be? | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | Ron's truck overheated. You got the starter from Ron. (bad joke) | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You should have at least 00 cables on a 6V. The battery ground should go to the bell housing. There should also be a ground strap between the bell housing and cab and another from cab to frame. It doesn't hurt to put another strap from bed to frame for good tail light grounding. | | |
