4 members (HandyAndy, klhansen, Gdads51, 52Carl), 103 guests, and 2 robots.
Topics128,062
Posts1,055,847
Members48,428
#44963 05/19/2005 4:25 AM
I bought an auto trans crossmember out of a 67 to use in my 66 C-10 V8 that was a manual truck. I was told that the early 60's through 72' would fit...I cant seem to get it in there. My original manual crossmember had the center torched out so removal wsa easy but no matter what angle I take at it the new one wont go in. Do I need to cut the rivets out of the auto crossmember so it is in 3 pieces then bolt it together?? Help!!
#44964 05/19/2005 3:21 PM
Yes, use 3/8 bolts to go back together. Put the two upper braces in after the crossmember is in. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
